Plusnet estimated 80M, only getting 40M
markr77
I've been on Plusnet fiber almost 6 months now, but I'm only getting half the speeds estimated by Plusnet.
I attach the relevant info. Any idea what the issue is? Perhaps my IP profile is stuck low for some reason.
Moderator's note by Mike (Mav): Telephone number removed from a public forum in file 2016-05-29-19-34-19.png
Fixes: 165
Re: Plusnet estimated 80M, only getting 40M
Whilst I understand that the estimates for your line are very good, you are on the lower of our 2 FTTC products. This is provided on a 40 down, 2 up wholesale service which is why you're seeing speeds of around 35Mb/s.
 Chris Parr
 Plusnet Staff
RealAleMadrid
Aspiring Champion
Fixes: 17
From your sync speed it is obvious your are on a 40/2 service. Are you supposed to be on Unlimited Fibre Extra? i.e. 80 Mbps download. You may have been put on the wrong product.
markr77
When I signed up, at no point was I aware there were '2 FTTC products'. So you gave me the higher estimate then put me on the lower product? There is only 1 product as a customer surely - 'Unlimited Fibre' the one I signed up to.
How do I find out the 'FTTC' product' I'm on, and what are my options to get the speeds you estimated?
IIRC 40/2 is unlimited fibre and 80/20 is unlimited fibre extra Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
markr77
OK, it makes sense. I must just be on the 'Unlimited Fiber' product with 40M max, in which case everything is fine Smiley
Please don't send me emails saying I should get 80M.
Fixes: 193
Apologies for any confusion caused by the higher estimates that were given despite being on the lower package. We'll make sure that's flagged up with the relevant people.
 Harry Beesley
Fixes: 71
The product you are on is shown at the top of the View My Brodband Usage display panel.
David
