Plusnet does have traffic management throttling speed
- Plusnet does have traffic management throttling sp...
16-05-2021 4:25 PM
I am sync at 79.99/19.99 from router straight to pc ethernet 1Gbps link speed and it appear plusnet does have real true speed continuous throttling limit download cap at 69Mbps and upload at 10Mbps?
Re: Plusnet does have traffic management throttling speed
16-05-2021 4:40 PM
This is my 'capped to 10Mbps' Upload results.
Whether you particular line is banded is another issue.
16-05-2021 5:44 PM
What software are you using to measure the speeds and tabulate them?
It is difficult to see from the table, is there a speed range in each download and upload cell?
How does the speedtest method manage bandwidth being used by other apps and users of the internet connection?
Regards
Richard
16-05-2021 5:59 PM
We don't throttle your speeds and, before you ask, the profile on your account is set to the max at 78000
Just checked your line and there's no capacity issues on the wholesale infrastructure at the exchange either.
However line tests are showing "Impairment in copper joint detected most likely in local network" so I'll put my money (Disclaimer: Figure of speech) that's where the issue is.
If you can raise a fault at faults.plus.net and post back afterwards, we'll be happy to arrange an engineer with you
16-05-2021 6:05 PM
@Gandalf Can you sent me GEA test result please
16-05-2021 6:09 PM - edited 16-05-2021 6:09 PM
I should've seen that coming Yeah sure I'm attaching it below
GEA Test Detail | ![]() |
16-05-2021 6:12 PM
@RichardB The software I ran this from here: http://startrinity.com/InternetQuality/ContinuousBandwidthTester.aspx
There is no one at my house just myself. Running it from router to pc ethernet on both windows 10 and linux still the same as download capped at 69Mbps and upload capped at 10Mbps. All TV, X box, wifi is offline just the pc and to the router.
16-05-2021 6:42 PM
16-05-2021 7:24 PM
16-05-2021 7:42 PM
@Gandalf just reply to your PM message. Thanks
17-05-2021 8:24 AM
My line is performing really well too!
19-05-2021 4:26 PM
19-05-2021 4:30 PM
19-05-2021 4:32 PM
@Gandalf Is the latest GEA Test still the same as before (outdated) or has they release a new one now?
19-05-2021 4:34 PM
@goldenfibre The only bit of a GEA test that's outdated is the "Profile Name". The remainder is current data especially the description part so it's possible that a fault has rectified itself and it's still lingering/may cause intermittent issues.
