Plusnet does have traffic management throttling speed
goldenfibre
Seasoned Pro
Fixes: 12
I am sync at 79.99/19.99 from router straight to pc ethernet 1Gbps link speed and it appear plusnet does have real true speed continuous throttling limit download cap at 69Mbps and upload at 10Mbps?
19 REPLIES 19
Fixes: 419
Re: Plusnet does have traffic management throttling speed
This is my 'capped to 10Mbps' Upload results.
Whether you particular line is banded is another issue.
RichardB
Seasoned Champion
Fixes: 39
Hi @goldenfibre
What software are you using to measure the speeds and tabulate them?
It is difficult to see from the table, is there a speed range in each download and upload cell?
How does the speedtest method manage bandwidth being used by other apps and users of the internet connection?
Regards
Richard
Fixes: 1,600
@goldenfibre
We don't throttle your speeds and, before you ask, the profile on your account is set to the max at 78000 Wink
Just checked your line and there's no capacity issues on the wholesale infrastructure at the exchange either.
However line tests are showing "Impairment in copper joint detected most likely in local network" so I'll put my money (Disclaimer: Figure of speech) that's where the issue is.
If you can raise a fault at faults.plus.net and post back afterwards, we'll be happy to arrange an engineer with you Smiley
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf Can you sent me GEA test result please
Fixes: 1,600
I should've seen that coming Smiley Yeah sure I'm attaching it below
GEA Test Detail
Circuit ID: N/A Service ID: [redacted]
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1625
Description Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report
Main Fault Location CE
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required Y
Fault Target Fix Time
Fault Report Advised Y
Estimated Line Length In Metres 243.6
Upstream Rate Assessment Very Good
Technology VDSL
DP Type External
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap
Cross Talk Not Detected
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2021-05-03T18:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 80.0 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 0.0 Sec 900.0 Sec 880.1 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-05-16T16:34:20Z 2021-05-16T16:49:20Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
goldenfibre
Seasoned Pro
Fixes: 12
@RichardB The software I ran this from here: http://startrinity.com/InternetQuality/ContinuousBandwidthTester.aspx
There is no one at my house just myself. Running it from router to pc ethernet on both windows 10 and linux still the same as download capped at 69Mbps and upload capped at 10Mbps. All TV, X box, wifi is offline just the pc and to the router.
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf @RichardB
Seem my line back to normal now
Fixes: 1,600
Nice! Let us know if there's anything else you'd need help with (I'll respond to your PM shortly though)
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf just reply to your PM message. Thanks
Mook
Seasoned Champion
Fixes: 9
My line is performing really well too!
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf
No issues here. Maybe the GEA test is old one (outdated) should be ok by now
Fixes: 1,600
Cool. Let me know if there's anything else you'd need help with Smiley
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf Is the latest GEA Test still the same as before (outdated) or has they release a new one now?
Fixes: 1,600
@goldenfibre The only bit of a GEA test that's outdated is the "Profile Name". The remainder is current data especially the description part so it's possible that a fault has rectified itself and it's still lingering/may cause intermittent issues.
