Plusnet combined Fibre router modem
Timalay
With BT supposedly phasing out the Openreach modem, any news on Plusnet doing a combined router modem for their Fibre packages.
davidwalker900
Re: Plusnet combined Fibre router modem
no atm i all ready asked unless you buy your own router with a Fibre router modem that can handle the speeds plusnet never invest in new routers for a long time too
BT use bt home hub 5 thats Fibre router modem (4 slots does up to 1000 Mbps) better signal wireless network
EE uses Bright Box 2  thats Fibre router modem (1 slot does up to 1000 Mbps 3 slots does up to 100 Mbps) better signal wireless network
    only two net providers do it now
PS  Plusnet runs off cheap routers for low costs £40 it costs plusnet (worst wireless network)
EE and BT routers cost the same around £125 - £175 but (free on sign up)
Marksfish
Got mine (new HH5) for £30 delivered off the bay!!
awahwah
I'm using our HH5 that served us when on BY Infinity,  Works a treat.
Timalay
How hard is HH5 to set up?  Does work fine without the OR modem?
davidwalker900
it works by signing in admin and copy the one is with the plusnet router with your signed up with password and plug in the dsl cable in to it and press connect its easy to set up without a modem
dragon2611
Quote from: davidwalker900
I very much doubt they're paying anything near the prices you quoted there for their routers, particularly in the quantities the likes of BT/EE will be buying them in.
davidwalker900
BT and EE quote's i did by the providers sites why stay with a cheap router that plusnet gives and you can get a better one with combined but mostly buy is the bt home hub then the EE one becuse that cost the most
kamalaggi
I'm currently using the Fritzbox 3390 with  built in VDSL2 modem/Wireless Router. It's working very well and the wireless signal is great.
