Plusnet capped speeds?
- Plusnet capped speeds?
Re: Plusnet capped speeds?
28-07-2018 2:16 PM
Many thanks for the info....So why have open reach done this and whats strange this
has happend after renewed contract...who gives the engineer permission to do this
i pay for extra fibre i dont expect to be capped for no reason.
As i said early on my neighbours are getting 68mbps theres are not capped
I shall wait till open reach sort this out but i am not happy.
someone between plusnet and open reach says capp
who is it who tells the engineer to do specific lines
Thanks guys for the info and help but i am not happy paying for something that is
not as i should be.
28-07-2018 3:51 PM
You need to understand more about how the system works. The "capping" by DLM is not a cap put on by an engineer who is just feeling awkward that day. DLM is a piece of equipment that monitors the performance of the line and allows it to run as fast as possible without letting the connection become unstable. That is, if your line were allowed to run any faster, you would start getting problems with disconnections and errors.
Your line for some reason is not capable of sustaining the same high speeds as your neighbours. This may be due to one of many issues such as poorly performing joints or noise such as cross-talk which is a function of where your pair sits in the cable.
So Plusnet are not guilty of capping your line and the fact that it happened after renewing your contract is pure coincidence. Don't forget, we are being provided with Mb data speeds over a old network that was designed to carry analogue signals up to 3.4kHz. There are lots of things that can go wrong and they frequently do.
28-07-2018 4:43 PM
What the capp has been put on by an engineer
I have been told that my line has been capable of sustaining the correct speed
by a bt engineer who checked my line
i have been getting these speeds 68mbps for over a 2 years
my next door neighbours fibre is at 67mbps my line is fault checked clear
no noise its been checked mate.
As coincidence of renewed contract i am not the only one google it
mine happened 2days later coincidence my foot.
28-07-2018 4:52 PM
Open reach has been told to remove the capp
So lets say the capp is removed by the engineer
what your saying is that dlm will set it back by itself again
so why would plusnet ask for my capp to be removed
if it wasnt set by the engineer.
28-07-2018 5:04 PM
the dlm system is a joke and shouldnt be used in all cases it sometimes cripples peoples good connections at no fault of there own wether theyve restarted there router or for whatever reason its to quick to make adjustments and too slow to put them back if it ever puts it back
its the worst system ever do they use this system in other countries ? or just ours
28-07-2018 5:13 PM
DLM is a joke In my case can the engineer overide the dlm and keep my proper speed
As i said earlier strange that my next door neighbour is stable at 67mbps
and my line has been tested fully clear.
I can and should get 72/67mbps line tested and this is what it always was until renewed contract
and they did up my profile to 72mbps because they lowerd my profile after renewel
I am getting just 49mbps now
I shall just hope plusnet gets them to REMOVE MY CAPPING AT 60mbps
This should never have happened.
28-07-2018 6:09 PM
After a lot of reading about DLM and banded line i have a question for you
As my line is banded or as the letter says capped will the engineer that is being
sent out to remove it reset my dlm aswell
Because what i have read is that the dlm has dropped my speed maybe due to router reset i dont know
Surely it would be good practice for them to remove my capp and reset my dlm
that way i would get back my 68mbps which i have lost for 7mths
seems that dlm is dropping my speed further as above reset router and my power cuts.
Just a thought guys
28-07-2018 6:12 PM
make sure you ask them to do that mate the last one wouldnt do it on mine cause he was an [-Censored-] of an engineer and didnt do a thing and blamed plusnet for not authorising it so make sure u ask them bud and dont let them go until they do hopefully u get a decent engineer
my problem still persists but nothing is being done about it
28-07-2018 6:13 PM
Sorry forgot to ask DLM can drop your speed quickly but how long does it take to increase it
whats the time scale
on 28-07-2018 6:14 PM - last edited on 29-07-2018 4:06 AM by Mav
Thanks mate good job ive started reading.
I wont rest till they have sorted this [-Censored-] out.
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
28-07-2018 6:17 PM
theres no exact figure on dlm it might never happen till they reset it physically
but plusnet dont like requesting it without good reason and it would save a lot of hassle for people they just dont get it im sure they think were mad requesting for a dlm reset
28-07-2018 6:46 PM
RE done jpg capped
28-07-2018 10:29 PM
DLM used to be a different beast. I was banded for a good year and all I did was change a socket in the house. I think it has improved of late.
What you have to understand is it is automatic and it monitors your line 24/7. Turn off your modem too many times and it might behave as if you have a fault on it. DLM reduced my line recently for some obscure reason but the last couple of weeks it has started to increase my line speed again (up by 3.5Mb). I don't really worry too much nowadays. As long as the thing works and I get a decent through put, I'm happy. While you can compare speeds with your neighbours, you might find crosstalk can also reduce your line speed - I think that is why my speed is coming back up, neighbours away on holiday.
Certainly if your line speed falls below your minimum, get PN to check it. Just fill in a fault ticket but do use a wired connection. WiFi can give strange results. Getting DLM reset used to mean an engineer visit to the cabinet. Not certain if that is still the case.
29-07-2018 11:15 AM
Pn are going to tell Oreach to reset my dlm
Just a thought will resetting the dlm remove my capp
or should the capp be removed same time as resetting dlm
If the capp is was done by dlm yes it should be fine
but if the capp was put on in another way it wont
How can i be sure the capp will be removed after resetting dlm
Confused over this
29-07-2018 11:26 AM
Its ok guys just read gandalf thread if dlm is reset capp banding will
be removed.
