Plusnet capped speeds?
sjptd
I am currently with BT on Fibre 2, syncing at 74.94/12.89.
I am considering moving (back) to PlusNet Unlimited Fibre Extra Broadband.
My assumption was that the line connection details would remain the same,
and typically the speeds would be pretty much the same with some differences because of load, backhaul etc.
BT inform me that PlusNet lines are capped at 66Mbps on the Unlimited Fibre Extra Broadband package.
I think that this is not true. Can anyone confirm that, please?
Plusnet say for my line ...
This means you can get our Unlimited Fibre Extra Broadband with an estimated download speed of 45 - 66Mb, and an estimated upload speed of 11 - 17Mb.
Your Minimum Guaranteed Access Line Speed for this product is 39.8Mb
Please excuse cross posting with ThinkBroadband, not sure which is more active at the moment.
Tags (1)
Fixes: 231
Re: Plusnet capped speeds?
Hi there.
Our speeds are advertised as estimated speeds of 66mbps due to ASA regulations but we don't cap people at 66mbps
 Matthew Wheeler
sjptd
Thank you.  That is what I thought but it is good to have confirmation.
Mark777
Yes they do capp i am livid with them.
Check out my email after a long time i got the truth.
Mark777
Sorry  will add in a second
Fixes: 176
For 'Capped' read 'Banded' which is something that Openreach's equipment applies to a line with issues in an attempt at stabilising it.
This is not something that Plusnet applies to a line but they can request a line reset which may clear the banding.
However there may be other issues on the line which have caused the banding to be applied and need addressing first.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Mark777
Ive added the proof they do capp  my speed dropped after new contract fibre extra
I was always getting 67mps then dropped to 55mbps now its 48mbps
It took a long time to get proof  i am livid  i pay for extra i should get extra
my line is fault free     check the jpg Capped
Moderator's note by Dick (Strat): CSA name(s) removed from attached image (to an area staff can see) as per Forum rules.
Fixes: 176
That isn't proof of 'capping' by Plusnet. See my post above.
idonno
My Line speed on the Unlimited Fibre Extra package is 'Current line speed:72.2 Mb' So utter BS from BT.
That's not to say the line speed might drop down at times but I have found PN fairly good for getting faults investigated / repaired whenever my line has truly gone South.
Mark777
My line is fault free so what your saying its not plusnet but open reach
So why can plusnet tell them to remove my capped line  who is the one
that decided to capp me in the first place.
An you tell me why plusnet dropped my speed after i re registered my account
Surely someone is telling open reach to capp lines.
idonno
DLM probably. Openreach control the sync speed via DLM (Dynamic Line Management). Active all the time. Just Google how it works.
Mark777
Thanks i shall read it .
Strange my neighbours are getting high 60s and i am not
because i am capped.
Shall leave plusnet and use who my neighbours have.
Job done
Mark777
Done some reading   Yes it is proof its in black and white my line is Capped
and plusnet have or are telling them to un capp my line  if they can tell open reach to un capp my
line then plusnet must have something to do with it in the first place and this happend
after new contract.....That is when my speed dropped
The plusnet engineer i spoke to said plusnet have told open reach to put a capp  on me.
Even the plusnet tech support was suprised and started to offer me compo.
It all stinks.
So dont say its not proof i think it is proof.
Mark777
Rubbish check my jpg
Moderator's note by Dick (Strat): Attached image removed as it contains a CSA name which is against Forum rules.
See attached image on post 7
sjptd
That note from Plusnet indicates that your line is indeed capped, but by Openreach DLM, not by Plusnet.  Exactly as mentioned by Strat above.  The Internet provider/Openreach relationship is most confusing especially when it comes to DLM (a semi- automatic Openreach system).  Under some cases a cap will be applied automatically by DLM but can only be undone by manual intervention, which requires your internet provider to contact Openreach.
