Plusnet VPN ERR_CONNECTION_RESET
corringham
All Star
Fixes: 8
Re: Plusnet VPN ERR_CONNECTION_RESET
@Bear1, sorry I can't really help with determining the cpu/memory loading for Plusnet routers - I use my own (Draytek 2860n+) which displays that information prominently.
Perhaps someone else can help? Anyone?
Bear1
@corringham Okay, no problem.  Interesting that you're using a different router though.
@BryceM61 I strongly recommend trying a different router if everything else in this thread doesn't help to rule out the Plusnet router being the culprit.
BryceM61
@Bear1 @corringham - thanks for the really fast replies.  I am at end of contract so I may just move.  I don't have a fibre compatible modem on hand.  Thanks again.
BryceM
BryceM61
@Bear1
I did just run it from a tethered 4g connection, and while not perfect, I did get a reliable 8Mb download which is a vast improvement.
Thanks again.
