Plusnet Proxy.
TheHorseman
Plusnet Proxy.
I'm seeing the error below, it only started this week. This message was generated when I tried to access the British Gas Hive info  page.
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /aem6/content/britishgas/products-and-services/hive.html.
Reason: Error reading from remote server
Anyone Else seeing this? It has happened twice tonight so far.
3 REPLIES 3
jimadine
Re: Plusnet Proxy.
Yes, me too! I'd rather assumed it was a problem at British Gas's end, though. Seems to be intermittent. The use of proxies might also explain why, since I moved to Plusnet, Santander online banking never recognizes my computer and puts up a security question (with Sky, this only ever used to happen once in a while, e.g. after I restarted the router).
TheHorseman
Re: Plusnet Proxy.
I'm sure I've seen the problem on other sites not just BG. Unfortunately I can't remember which ones. As you say it is intermittent. I will have to make a note of which sites when and if it happens again.
St3
Aspiring Champion
Fixes: 5
Re: Plusnet Proxy.
hi guys maybe im affected by the same thing as you ... read my post https://community.plus.net/t5/Fibre-Broadband/Still-getting-dns-issues-with-2-websites/td-p/1377928
