Plusnet Profiles, Static IPs and the New Network
pjmarsh
Fixes: 20
Hi
I was on the new network before moving house, so an guessing I still am after moving house, but couldn't be sure.  I have a static IP.  Does the Plusnet Profile still apply with this?  I have a vague memory of it being done differently on the new network, but wasn't sure if the scenario with static IPs used it or not?
Anyway to my issue.  Since my house move I've been syncing pretty much to the maximum (as I'd expect.  I can see the cabinet from my window!), but speed tests are coming back at around 20Mb download.  The BT Wholesale test is giving an error on the further diagnostics part.
I put it down at first to the powerline adapters I'm using at the moment until I do a little building work around where I'm going to put my office, so to be sure, I've just disconnected them and connected directly to my router via Ethernet with the same results (though better upload).
So basically, if the Plusnet profile is still in play for my connection, could someone check/reset it for me please?
Phil
2 REPLIES 2
HarryB
Fixes: 256
Re: Plusnet Profiles, Static IPs and the New Network
You are still on the new network, however as you have a static IP, the profile on your account would still come in to play.
I've corrected this for you so a disconnect/reconnect should get you back up to speed. Apologies for any confusion/inconvenience that caused.
 Harry Beesley
pjmarsh
Fixes: 20
Many thanks @HarryB, that is much better when I'm not using the powerline adapters!
Phil
