Plusnet Pro
stevemac555
Plusnet Pro
Sorry me again...
I've just found the "Plusnet Pro" addon in my account for an extra £5/month and have a couple of questions..
1) I am on Unlimited fibre. Currently at 14518 / 56917 and have a ping to game servers at around 18ms. The FAQ states "With Plusnet Pro latency is lower and ping times are quicker than standard broadband." Does this apply to Fibre? Not sure how I can get much better than an 18ms ping.
2) If I sign up to this, is there any downtime and how quickly is this activated?
Not 100% bothered about the gaming, but the prioritized VPN traffic would come in handy for work.
Thanks,
Fixes: 127
Re: Plusnet Pro
it really wouldn't serve any purpose for you.
Will Moderate For Thanks
Fixes: 46
Re: Plusnet Pro
The only effect you are likely to notice is an extra £5 per month on your bill. Roll eyes
This add-on was useful on legacy products subject to major traffic shaping but not for the current range of products. It remains available to give customers the choice, but I'd be surprised if you noticed a difference.
David
Fixes: 18
Re: Plusnet Pro
Hi stevemac555,
I have always found that this add on is great for customers on longer lines but sometimes with our new fibre products its not necessary to have it. If you did take the add on though there will be no downtime.
 Ben Babinski
stevemac555
Re: Plusnet Pro
Thanks all.
It does seem a bit misleading seeing this as an addon, with the descriptions of reducing latency, prioritising traffic etc. if in fact, it does nothing at all for my connection?
I actually clicked 'Add' thinking it would give me more details/confirmation but it seems to have been applied straight away. I'll see if it makes a difference this month and cancel if not.
Thanks,
rongtw
Fixes: 12
Re: Plusnet Pro
OOOPs you just wasted a £5 Shocked
Fixes: 46
Re: Plusnet Pro
A pictorial representation of what the Pro Add-on does is shown by comparing the left hand and right hand frames in the following screen shot. This came from the UserGroup Product Comparison Tool (http://usergroup.plus.net/newprodcomp.php). I selected Plusnet Unlimited Fibre and Pro Add-on from the drop-down selectors. The coloured data remains valid though the admin data at the top (removed on the image) relates to what is now a legacy product.
In principle it's fair to say it *does* do what it says on the tin for your connection, but the question is really "would you notice?". My personal view is that you won't but trying it will show for sure.
There is a tendency to think that the picture shows P2P traffic is slowed down - but that isn't the case; it's priority is reduced but it downloads at line speed provided nothing with higher priority (eg streaming) is competing for the available bandwidth. Generally for fibre customers bandwidth availability is not a problem.
I hope this helps your understanding of what the add-on does. Smiley
David
