Plusnet IP Profile
Muttley62
Plusnet IP Profile
I have noticed that my BT IP Profile has recently increased to 46.05 having always been around 39 ish.  I went to check that my Plusnet settings matched but this facility seems to have been removed from the connection settings within the member centre.  Can someone please check that the settings match in my case.
Estragon
Re: Plusnet IP Profile
Add https://portal.plus.net/my.html?action=data_transfer_speed to your Favorites/Bookmarks. Clicking it will give you the Portal login screen, which when completed sends you to the page.
Muttley62
Many thanks for that.  As I thought, it is still at 39.8 - can someone from Plusnet change it to match the BT IP profile of 46.05 please.
Fixes: 188
There seems to be a bit of a mismatch somewhere.
Our tests are showing your modem as syncing around 40mbps which makes the profile correct.
Where are you seeing the BT profile as being 46mbps? Can you attach a copy of the BT Speedtest you carried out?
 Matthew Wheeler
alext05
Hi Matthew, I have a similar request to OP.
I did a BT performance test this morning and it said: IP Profile for your line is - 76.47 Mbps (cannot provide a screenshot as not at home atm). My speed test only gives me 63Mbps after jumping to 75Mbps at the start of the test.
Can someone please amend my Plusnet's profile. Thanks.
MattyC
Champion
Fixes: 46
Hi Alex,
This is a rare occasion, but it looks like the two profiles have mismatched. I've changed ours, so if you log into you router and hit disconnect/connect you may see improvements.
Matty
alext05
Many thanks, Matty. Will do this when I get home in the evening. Smiley
alext05
Hi Matty/Plusnet. Just to confirm that I am now getting 74Mbps. Thanks for your help. Happy days!  Cheesy
MattyC
Champion
Fixes: 46
Decent  Cool
alext05
Will do for me.  Grin
Muttley62
Here is the screenshot from a speed test today - clearly states IP Profile 46.05
MattyC
Champion
Fixes: 46
Your profile actually changed by automation yesterday so it's now at 46. Hopefully this sorts it.
Matty
Muttley62
