Plusnet IP Profile
- Re: Plusnet IP Profile
Plusnet IP Profile
14-07-2015 9:29 PM
14-07-2015 9:34 PM
14-07-2015 9:54 PM
15-07-2015 10:42 AM
Our tests are showing your modem as syncing around 40mbps which makes the profile correct.
Where are you seeing the BT profile as being 46mbps? Can you attach a copy of the BT Speedtest you carried out?
15-07-2015 10:58 AM
I did a BT performance test this morning and it said: IP Profile for your line is - 76.47 Mbps (cannot provide a screenshot as not at home atm). My speed test only gives me 63Mbps after jumping to 75Mbps at the start of the test.
Can someone please amend my Plusnet's profile. Thanks.
15-07-2015 11:25 AM
This is a rare occasion, but it looks like the two profiles have mismatched. I've changed ours, so if you log into you router and hit disconnect/connect you may see improvements.
Matty
15-07-2015 11:28 AM
15-07-2015 5:20 PM
15-07-2015 5:21 PM
15-07-2015 5:22 PM
15-07-2015 5:31 PM
16-07-2015 10:28 AM
Matty
16-07-2015 4:51 PM
