Plusnet Hub Zero 2704n review
- Plusnet Hub Zero 2704n review
06-08-2015 9:40 PM
Re: Plusnet Hub Zero 2704n review
07-08-2015 7:09 AM
also incorrect they say you can mount it on a wall when it comes out of the box Its IMPOSSIBLE to wall mount with the holes provided , the cables will not allow it .
you actually need to manufacture a bracket yourself to make it wall mountable , i know i did it
07-08-2015 9:11 AM
07-08-2015 9:33 AM
If like me you have multiple devices on wifi, kids on Netflix, wife on PS4 paying online and running media servers from main pc, then avoid this like the plague. For me it keep kept dropping wifi and the signal was really bad, I mean really bad. Lost 75 percent of sign over old plusnet ADSL router sited in same position.
They should stop giving this altogether and offer a far better one. Something that is a bit more reliable.
07-08-2015 9:42 AM
Quote from: rongtw also incorrect they say you can mount it on a wall when it comes out of the box Its IMPOSSIBLE to wall mount with the holes provided , the cables will not allow it .
Actually, in specifications box it says: Wall mountable: No, so they agree with what you said.
The opening of the review is rather damning:
"BT-owned Plusnet is one of the cheaper ISPs out there, and with such low contract prices, you might feel the company could be excused for providing a less than optimal free router. Even with this in mind it’s difficult not to come away from its new Hub Zero 2704n router without feeling rather disappointed."
07-08-2015 9:50 AM
Discussed at length in a much earlier thread - even with angle connectors you still need a hole dug in the wall or a thick standoff
07-08-2015 11:45 AM
and 2 mirror image of them
07-08-2015 12:35 PM
07-08-2015 5:01 PM
this was how i did it with a 40mm stand off bracket i made , 2 holes for screws to wall & 2 with nuts and bolts lined up with Fast 2704 slots in back
07-08-2015 5:33 PM
07-08-2015 6:43 PM
wasjust to show the wall mounting bracket
07-08-2015 7:25 PM
07-08-2015 10:36 PM
08-08-2015 12:01 AM
Just a thought.
08-08-2015 9:51 AM
