Plusnet Hub One
gc66
Plusnet Hub One
Anybody know if you can get CLI access to these? I need to set the default gateway on this to an IP address different from the router itself, but this is not available within the GUI
Fixes: 388
Re: Plusnet Hub One
no, you can't get any CLI access.
My Broadband Ping - PN-Fibre
gc66
Re: Plusnet Hub One
Great... Thanks for the reply.  that's that 2nd thing that's causing me an issue with this, the other being you can't set the LAN IP to 10.0.0.0/8 or /24
