Plusnet Hub One
- Plusnet Hub One
Plusnet Hub One
11-12-2015 2:37 PM
Anybody know if you can get CLI access to these? I need to set the default gateway on this to an IP address different from the router itself, but this is not available within the GUI
Message 1 of 3
(958 Views)
2 REPLIES 2
Re: Plusnet Hub One
11-12-2015 2:40 PM
no, you can't get any CLI access.
Message 2 of 3
(512 Views)
Re: Plusnet Hub One
11-12-2015 2:45 PM
Great... Thanks for the reply. that's that 2nd thing that's causing me an issue with this, the other being you can't set the LAN IP to 10.0.0.0/8 or /24
Message 3 of 3
(513 Views)
