Plusnet Hub One not working | Forced to use TalkTalk VDSL |
wwex786
Ever since yesterday my Plusnet Hub One just stopped working. I went on the 192.1681.1.254 settings and I saw that it was "Disconnected" so I pressed "Connect" but it didn't help. All it did was disconnect straight away. I gave it a bit of break incase it was an error but the fault still persist. I tried factory resetting it and even then I had no luck. I now have swapped to the TalkTalk VDSL router since I don't have an Openreach modem Sad This instantly connected and I was good to go  Smiley I have WAN routers at home but I am guessing I can't use them? Is it in any way possible that I can make a spare, VDSL router into a home made Openreach modem so that it gives off a WAN connection? If this is possible, can someone guide me in doing so?  Sad
