Plusnet Hub One is producing broadcast storm on local network
andrum99
I've just connected to Plusnet's residential FTTC 40/10 service having been with another ISP. For some reason the supplied Plusnet Hub One router is spamming my local network with a large number of broadcast packets. As with my previous ISP, I've all wired traffic going through a smart switch that has broadcast storm control, but I've never had to use this feature before. I turned it on and set it to the lowest rate - 512Kbps - and it seems to have filtered out most of the rubbish coming from the Plusnet router. Is there a way I can fix the router so it doesn't send out so much rubbish on my local network?
4 REPLIES 4
SammyM
Fixes: 67
Re: Plusnet Hub One is producing broadcast storm on local network
Hello @andrum99,
I am sorry to hear that our router is doing this, it is possible that it is faulty causing it to act in this manner. I have arranged for a new one to be sent out and please get back to us if this still occurs as we will contact our products team at that point.
 SammyM - Sheffield Team
andrum99
No need to send out a new router - it seems to just be a feature of the firmware. I'm not seeing nearly as much broadcast traffic now, so whatever was causing it seems to have settled down.
andrum99
I see that this is now showing in my account control panel as if I requested an RMA on the Hub One. I did not. Please cancel the router swap as it is not required.
Optimatts
Fixes: 19
No problem @andrum99 I've cancelled the RMA. Thanks for letting us know.
