Plusnet Hub One firmware level
FIXED- Subscribe to RSS Feed
- Plusnet Hub One firmware level
16-08-2018 6:31 PM
I raised a ticket this morning but no reply yet (#181123706)
This evening I plugged back in the BTHH6 and now its working fine again, so I suspect a router/firmware problem, how can I tell if I've got the latest firmware or not ?
Simon
Fixed! Go to the fix.
Re: Plusnet Hub One firmware level
16-08-2018 6:49 PM
That is the latest Hub 1 firmware but it isn't a good modem/router, it's a rebadged BT Homehub 5a so a pretty old design. I would keep using the HH6, I think that will be a lot better, I don't have one myself, I never use ISP supplied routers but there are reports that the WIFi is good and it has a better modem chipset.
16-08-2018 7:31 PM
The BT HH6 is a better router, use that rather than the PN Hub1.
17-08-2018 9:48 AM
17-08-2018 10:46 AM
@Gandalf In the opening post the OP states his firmware version is 4.7.5.1.83.8.259. I thought that was the latest with a change to stop the connection dropping when the line has lower SNRM values, i.e. below 6dB. Also if the OP is using the BT HH6 now your "upgrade" is not going to work.
17-08-2018 4:15 PM
I'm not actually sure what the latest firmware version is which helps lines on 3dB, but when our products team (Likely to be Bob) picks up the task/question I've posted they'll be able to advise or reject the request accordingly.
Unless I'm mistaken(And I could be), it should still work because the router is still showing as enabled on our TR069 management platform.
Anoush Mortazavi Plusnet Help Team |
17-08-2018 5:26 PM
thanks for all the replies.
Since switching to BTHH6 connection has been solid for last 24hours.
@Gandalf is there an ftp site I can download and apply this update from? I'm happy to try +net Hub1 again but waiting for around a week with no/little Internet access isn't really an option for me.
Technical Log BTHH6 shows -
BT Hub 6A
+084319+NQ64887592
SG4B1000B540
16-May-2018
1.0
1.64.0
1 Days, 0 Hours 1 Minutes 33 Seconds
10.00 Mbps / 40.00 Mbps
14422 / 61175
10 dB / 13.5 dB
17.5 dB
0/38
G_993_2_ANNEX_B
Fast Path
319 MB Uploaded / 1781 MB Downloaded
xxxxxxxxxx@plusdsl.net
Not active
TALKTALK-FD4864
Smart (Channel 11)
TALKTALK-FD4864
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
24:20:C7:6F:F3:09
7.33.1
17-08-2018 5:37 PM
17-08-2018 5:38 PM
PlusNet do not have any update for your Hub 1, you are already on the latest version so its not going to change anything. I would keep using the HH6.
18-08-2018 12:11 PM
.259.1.1 is actually the latest version but we've no customers running it (yet). The only place it differs from .259 though is the embedded cert authorities i.e. upgrading from .259 to .259.1.1 is not going to help here.
18-08-2018 6:38 PM
thanks. So if this is not a firmware issue what do you suggest?
or should I just give up and use my existing HH6 as suggested by @RealAleMadrid
2 Days, 1 Hours 13 Minutes 17 Seconds
18-08-2018 8:01 PM
I've just recently swapped out my PlusNet Hub which kept on dropping connections for a low cost replacement which has managed a week without dropping connection. If you are interested it is a Netgear DM200. You need a separate WiFi solution for that device, which suited me because I've switched to a mesh WiFi system to get whole house seemless connection.
19-08-2018 1:09 AM
My mate & I was thinking the same thing that PN Hub One is very poor overall router with lots of dropping sync rate. Openreach engineer at his house told me that he would recommend BT Hub 6A rather than PN Hub One. Now, my mate getting fed up with hub one flashing orange yesterday (Saturday) and I did advised him to get back to PN and say there is a fault on his line after third engineer. Nothing to do with DSL cable, Nothing to do with no fault found. I do genuinely believe it PN Hub One keep letting him down. Avoid Hub One at all cost.
19-08-2018 2:09 PM
Regarding subsequent posts, there are no acknowledged DSL stability issues affecting the .259 firmware (excluding one uncommon issue that prevents you obtaining sync at all), so if anybody has evidence suggesting otherwise then I'm keen to hear it.
19-08-2018 2:14 PM - edited 19-08-2018 2:17 PM
@bobpullen can you please send firmware to my mate hub one router as his hub one router still on old firmware might affect his sync keeping dropping issues.
His hub one firmware software are: 4.7.5.1.83.8.237.2.2
