Plusnet Hub One faulty / unstable connection
- Re: Plusnet Hub One faulty / unstable connection
27-11-2020 1:39 AM
I have an issue with my Plusnet Hub One where the connection drops out systematically every 30 seconds. It happens with wired and wireless connections. Every device attached is affected Here is a couple of ping plots to show;
WIRELESS (Laptop)
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=776ms TTL=64
Reply from 192.168.1.254: bytes=32 time=795ms TTL=64
ETC ETC...
WIRED (PC)
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=714ms TTL=64
Reply from 192.168.1.254: bytes=32 time=775ms TTL=64
ETC ETC...
The connection drops EVERY 30 seconds for a second without fail, until I turn the router off and on again. it will be stable for about half a day and then it will carry on with the continuous dropouts. This makes gaming and video calls horrendous to deal with and would like to a solution that doesn't involve continuously resetting the router. Firmware version is currently 4.7.5.1.83.8.263
27-11-2020 8:48 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
