Plusnet Hub One crashes for a minute then reboots
- Plusnet Hub One crashes for a minute then reboots
29-04-2020 3:13 PM
For a while now my router has been losing connection every so often, the problem is random not really in a pattern sometimes it can be a day or two without it happening.
but recently it has been doing it way more often which is an issue, cutting out meetings etc.
I have logs from the router here hopefully it helps identify the problem.
20:10:34, 28 Apr. | (446410.420000) CWMP: session completed successfully |
20:10:34, 28 Apr. | (446410.170000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
20:10:29, 28 Apr. | (446405.190000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:10:29, 28 Apr. | (446405.180000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:10:26, 28 Apr. | (446402.570000) WAN operating mode is VDSL |
20:10:26, 28 Apr. | (446402.570000) Last WAN operating mode was VDSL |
20:10:24, 28 Apr. | (446400.560000) PPP IPCP Receive Configuration ACK |
20:10:24, 28 Apr. | (446400.540000) PPP IPCP Send Configuration Request |
20:10:24, 28 Apr. | (446400.530000) PPP IPCP Receive Configuration NAK |
20:10:24, 28 Apr. | (446400.530000) PPP IPCP Send Configuration ACK |
20:10:24, 28 Apr. | (446400.520000) PPP IPCP Receive Configuration Request |
20:10:24, 28 Apr. | (446400.520000) PPP IPCP Send Configuration Request |
20:10:23, 28 Apr. | (446398.720000) PPPoE is up - Down Rate=44501Kbps, Up Rate=11999Kbps; SNR Margin Down=6.1dB, Up=6.1dB |
20:10:23, 28 Apr. | (446398.710000) CHAP authentication successful |
20:10:23, 28 Apr. | (446398.650000) CHAP Receive Challenge |
20:10:23, 28 Apr. | (446398.640000) Starting CHAP authentication with peer |
20:10:23, 28 Apr. | (446398.640000) PPP LCP Receive Configuration ACK |
20:10:23, 28 Apr. | (446398.630000) PPP LCP Send Configuration Request |
20:10:23, 28 Apr. | (446398.630000) PPP LCP Receive Configuration Reject |
20:10:23, 28 Apr. | (446398.620000) PPP LCP Send Configuration ACK |
20:10:23, 28 Apr. | (446398.620000) PPP LCP Receive Configuration Request |
20:10:23, 28 Apr. | (446398.620000) PPP LCP Send Configuration Request |
20:10:09, 28 Apr. | (446384.820000) PTM over DSL is up |
20:10:01, 28 Apr. | (446377.420000) CWMP: session closed due to error: Could not resolve host |
20:10:01, 28 Apr. | (446377.400000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:10:01, 28 Apr. | (446377.390000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:09:41, 28 Apr. | (446357.250000) Admin login successful by 192.168.1.64 on HTTP |
20:09:33, 28 Apr. | (446348.930000) New GUI session from IP 192.168.1.64 |
20:09:31, 28 Apr. | (446347.050000) CWMP: session closed due to error: Could not resolve host |
20:09:31, 28 Apr. | (446347.020000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:09:31, 28 Apr. | (446347.010000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:09:31, 28 Apr. | (446346.650000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
20:09:27, 28 Apr. | (446343.170000) PTM over DSL is down after 269 minutes uptime |
20:09:27, 28 Apr. | (446343.170000) PPPoE is down after 269 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
20:09:24, 28 Apr. | (446339.830000) PPP LCP Send Termination Request [User request] |
sometimes the log is not that long and only includes (Send Termination Request) to (PTM over DSL is up)
Any help would be greatly appreciated!
My Plusnet Hub One keeps cutting out
29-04-2020 4:34 PM
This has been happening for a while now, every so often my broadband cuts out and then a minute later it will reconnect, I have logs of what happens in the router and would be great if someone could help fix or give me some guidance on what to do!
Thanks Alex
Re: My Plusnet Hub One keeps cutting out
30-04-2020 7:17 AM
Moderators Note
This topic has been released from the spam filter and merged with another one from OP.
01-05-2020 12:46 PM
