Plusnet Hub One and iPhone 4S problems
- Re: Plusnet Hub One and iPhone 4S problems
28-01-2016 8:54 AM
I have recently installed a Hub One router in advance of a switchover to fibre. My iMac, laptop and iPad all work beautifully on Wifi with the new router, but I have problems with my iPhone 4S. For much of the time it is constantly oscillating in and out of Wifi. I did not have this problem with my previous Thomson router, and it is interesting that my wife also has an iPhone 4S and has exactly the same problem. Any suggestions please?
Message 1 of 6
(1,641 Views)
5 REPLIES 5
28-01-2016 9:56 AM
we had an issue with one of our macs - best solution is to split the 5GHz network into its own SSID.
Message 2 of 6
(877 Views)
28-01-2016 10:53 PM
Thank you Dvorak. I don't really know what I am doing, but I gave a new SSID to the 5 GHz wireless configuration. I am pleased to report that so far it seems to have cured the problem. As a non-techie I don't understand the difference between the 2.4 GHz and 5 GHz configurations. Everything else seems to be working ok, but I am hoping all will still be alright once my line has been converted to fibre in the near future.
Message 3 of 6
(877 Views)
29-01-2016 8:56 AM
Newer routers offer both 2.4 and 5GHz WiFi as both have their pros and cons.
2.4GHz has better range, but is more prone to interference as that band is pretty crowded by other routers, cordless DECT phones, etc. In contrast, 5GHz isn't as susceptible to interference, but doesn't penetrate through solid things (e.g. walls) as well as 2.4, so its range isn't as good.
Message 4 of 6
(877 Views)
29-01-2016 8:58 AM
No worries, glad it's helped
Message 5 of 6
(877 Views)
16-02-2016 12:30 PM
Sorry to report that after I thought I had considerable improvement, my iPhone 4S started to drop the Wifi signal again. It happens spasmodically, and you can watch it log in, and a few seconds later it reverts to 3G. Oddly it seems ok in the mornings, but by the evening it continually drops in and out. My wife, who also has an iPhone 4S, has the same problem. Everything else in the house works fine: iMac, iPad, TV and PC. I can confirm that I have altered the SSID of 5GHz. I haven't come back to the forum earlier because I was just hoping it would clear itself. Bit of wishful thinking!
Message 6 of 6
(877 Views)
