Plusnet Hub One - all my devices are running at 2.4 GHz??
FIXED- Subscribe to RSS Feed
- Plusnet Hub One - all my devices are running at 2....
22-10-2018 4:08 PM
all my devices in my family from iphones to PS4 they are all running at 2.4GHz and are really slow and keep on freezing on websites etc.
I've spoken to apple and they've said your routers firmware probably needs updating? please can you advise how I do this the latest firmware I have is below:
Software version 4.7.5.1.83.8.237.2.2 Last updated Unknown
This is very frustrating as have had some problems with it and have had to reset the Plusnet Hub One on many occasions.
Please can this be looked at asap.
Kind Regards
Rob
Fixed! Go to the fix.
Re: Plusnet Hub One - all my devices are running at 2.4 GHz??
22-10-2018 4:18 PM
It requires some effort on your part.
What signal strength do you get on your wifi?
Is your router located anywhere near your devices?
Have you tried a wired connection on any devices?
What kind of download speed does your router get anyway.
Check these things - ASAP.
22-10-2018 4:31 PM
i'm OK with a bit of effort as this speed is useless.
yeah router is literally a few meters away
just ran a speed test and i'm only gettingn 38.1 dload and 13.7 upload
the signal strength on my iphone is full bars
22-10-2018 4:31 PM
22-10-2018 4:51 PM
Was that speedtest done over wifi or ethernet cable?
22-10-2018 5:12 PM
i just reset the hub now a few devices are running on 5ghz but i shouldnt have to keep on resetting the hub should i?
the speed test over wifi is now at 61.5 dload and 12.9 upload
22-10-2018 5:30 PM
Configure your router to have separate SSID's for the 2.4 & 5GHz.
You can then configure your devices to connect to the SSID that gives the most reliable/highest speed.
22-10-2018 5:41 PM
As per @VileReynard advice see here: https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1543424#M6581 . Then go into your device available wireless network settings and try each channel. Use the one that gives the best performance.
22-10-2018 5:52 PM
Should that be the case?
22-10-2018 8:42 PM - edited 22-10-2018 8:44 PM
That's what worked for me a while back. 5GHz may not have the range but the speed is great. I also specified a channel rather than leave it on automatic. WiFi from the neighbours was causing a bit of interference. I made my devices forget the 2GHz or they would try to connect to it sometimes.
