Plusnet Hub One Router - bundled cable twisted?
- Re: Plusnet Hub One Router - bundled cable twisted...
01-12-2015 8:25 PM
HI all,
Just wondering if anyone was in the know about this, I am curious to know if the RJ11 lead in the Hub One bundle was straight or twisted?
Im assuming it will be a cheap straight lead but i hear some ISP's are providing better twisted ones so just thought id ask
Many Thanks
Lee
Many Thanks
Lee
Message 1 of 6
(1,113 Views)
5 REPLIES 5
Re: Plusnet Hub One Router - bundled cable twisted?
01-12-2015 8:33 PM
straight.
Message 2 of 6
(694 Views)
01-12-2015 8:36 PM
The one that was in the Hub One box that I received is white with yellow ends, but it appears to be Straight
Message 3 of 6
(694 Views)
01-12-2015 8:43 PM
Thanks for the information guys Further to this has anyone had experience with the real world benefits of a twisted lead?
Lee
Lee
Message 4 of 6
(694 Views)
01-12-2015 8:47 PM
not on fibre, adsl it gave a little more oomph.
Message 5 of 6
(694 Views)
02-12-2015 12:56 AM
Sorry I misread your question I thought you meant the Ethernet cable not the phone cable. Phone cable is flat with grey ends. It's marked 26AWG which should be better than for instance 28AWG so the conductor wires have larger radius, and lower resistance / length. It shouldn't make much difference unless the RJ11 cable is very, very long, or is at a length where it is in effect acting as an aerial for a source of radio interference. Twisted should in theory reduce interference.
Simple to test, use another RJ11 cable, and see if you find any difference. Or make your own up using a pair of RJ11 connectors, and a section of Cat6 shielded cable, make the cable as short as you can within reason.
Or just check out online auction sites, and get a shielded twisted RJ11 cable, a 1m cable should be around £5.
You may get a fraction more from your line, but if your line is giving you 73Mb/s before, and you get 74Mb/s you're unlikely to notice the difference.
Message 6 of 6
(694 Views)
