Plusnet Hub One- Random high pings, making me disconnect.
mckenzie2008
Hey guys, first post yay!
I'm posting because recently I've been getting disconnected from games, but my internet itself isn't slow, just for some reason my ping jumps from say 20ms, to almost 200ms, and drops down which is causing me to disconnect?
Also I'm not getting the broadband speed I should be getting and what I'm paying for...
I attached a photo below, saying what i should get, and a picture showing what i actually get using a speed-tester.
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Plusnet Hub One- Random high pings, making me disconnect.
Hey there, first of all a warm welcome to the community forums
I am sorry that your thread hasn't been replied to. I've just tested your line, and posting the results below.
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 323.5
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off
From the above I'm not able to identify an issue. Your connection from the exchange to your router is also pretty stable:
I'd first advise to try a reboot (or disconnect/reconnect the PPP session in your router interface)
Also, are you using a wired or wireless connection?
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
