Plusnet Hub One Gateway Address
digitl
After having connectivity issues Plusnet have replaced my old router with a Plusnet Hub One.
The old router used IP addresses of the form 192.168.178.x and so I have set the PHO to use 192.168.178.1 - 192.168.178.254 (with the router at 192.168.178.1) as I have quite a few devices on the network with fixed IP addresses.
I am a little puzzled as the gateway address has been automatically set as 195.166.130.252 rather than the 192.168.178.1 that I had expected. Is this correct and, if it's not, how can I change it? I have searched for an option...!
3 REPLIES 3
Seasoned Champion
Fixes: 38
Re: Plusnet Hub One Gateway Address
Please do not double post it is against forum rules - see
digitl
I am aware of that. There was good reason.
Strat
Fixes: 565
Moderator's note by Dick (Strat): Topic locked in favour of this one.
