Plusnet Hub One Flashing Orange Light
FIXED- Subscribe to RSS Feed
- Plusnet Hub One Flashing Orange Light
05-01-2019 9:39 PM
Upgraded about 9 months ago to Hub One and all has been fine. Then today all stopped working with an orange flashing light and no other indications. Spoke to technical support who ran through resetting and then manually entering the username and password. No Joy with the comment the router must be damaged... now we're being sent a new router at our cost for the postage.
Is this common for the routers to suddenly fail after 9 months?
What does the orange flashing light indicate as it's not mentioned in any of the guides?
Thanks, Jayne
Fixed! Go to the fix.
Re: Plusnet Hub One Flashing Orange Light
06-01-2019 10:04 AM - edited 06-01-2019 10:20 AM
Left "faulty" router overnight and it's come back to life. The helpdesk information reads as follows:
1. Product name: | Plusnet Hub |
2. Serial number: | +081441+NQ80697093 |
3. Firmware version: | Software version 4.7.5.1.83.8.237.2.2 Last updated Unknown |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 0 days, 02:33:13 |
6. Data rate: | 135 / 20944 |
7. Maximum data rate: | 139 / 24482 |
8. Noise margin: | 6.3 / 6.2 |
9. Line attenuation: | 31.1 / 27.8 |
10. Signal attenuation: | 10.3 / 26.6 |
11. Data sent/received: | 23.8 MB / 84.5 MB |
12. Broadband username: | **** |
13. 2.4 GHz Wireless network/SSID: | ***** |
14. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
15. 2.4 GHz Wireless security: | WPA2 |
16. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
17. 5 GHz Wireless network/SSID: | ***** |
18. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
19. 5 GHz Wireless security: | WPA2 |
20. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
21. Firewall: | Default |
22. MAC Address: | ***** |
23. Modulation: | G.993.2 Annex B |
24. Software variant: | AA |
25. Boot loader: | 1.0.0 |
Any advice anyone as to how to stop this happening? If there a firmware update?
Thanks, Jayne
06-01-2019 10:18 AM
@Jayne_with_a_Y - if flagged this last post to the mods to edit as it contains your username, which shouldn't be put on here for your account safety. You might be able to edit this yourself quicker than a Mod can pick this up.
Do you know what firmware version the router is running? it should say on the home interface page.
Thanks,
MoR
06-01-2019 10:23 AM
@MasterOfReality many thanks and I've edited the post
The firmware version is in the post "Software version 4.7.5.1.83.8.237.2.2"
Thanks, Jayne
06-01-2019 5:15 PM
Hi Jayne,
There is an update. Though it's not specifically designed to resolve the issue you've described I'd definitely recommend updating it as a matter of course - could you keep your router turned on and I'll ask one of my colleagues to roll this out to you?
@bobpullen would you mind pushing an update for this one?
Best wishes
Dave
06-01-2019 5:46 PM
does the firmware on hub one not automatically update ? As im on the same firmware as @Jayne_with_a_Y and Youve said it's highly recommended to update
06-01-2019 5:47 PM
@MasterOfReality Has it been a long day ? !
From the above table:
06-01-2019 7:48 PM
@RandallFlagg Hi, thanks for helping. The router is normally on 24/7 so should be no problem.
07-01-2019 10:55 AM
Hi @jayne_wish_a_Y, I believe we may have over eagerly ruled the cause of your connection issues to be firmware related here as when testing today I can see a line fault looks to be being detected which explains the loss of connection yesterday morning for a long period when you initially got in touch.
I have raised this external looking line fault to our suppliers to investigate and they have given us the estimated response time of 09/01/19 by 23:59 (keeping in mind this can be resolved sooner)
I'd advise then moving forwards to monitor the connection your side over the coming days and if you are still seeing issues come the morning of 10/01/19 please do let us know and we can investigate this further.
07-01-2019 10:56 AM
Hi @daleh43, are you having any connection issues at all that could be firmware related? We would explore into any and all issues you're having first before we looked at manually pushing out firmware updates.
07-01-2019 11:02 AM
Thanks @BD for letting me know.
09-01-2019 9:33 PM
@BD our connect is still extremely slow - the Apple TV is struggling to show BBCi Player programmes for example. I ran a speed test from my laptop connected by wifi to the router with download showing as
Ping 294 ms
Download1.70 Mb/s
Upload0.10 Mb/s
So just a bit pants!
10-01-2019 1:02 PM
Thanks for the update - I'm sorry that this is still problematic for you.
I've checked this with our suppliers and its looks as though an external fault may still be apparent.
I'm going to monitor this and ensure that any work that needs to be done is done ASAP to get you up and running again.
I'll provide more info as and when I have it.
Best wishes
Dave
11-01-2019 5:20 PM - edited 11-01-2019 5:21 PM
it's still very slow...
5. DSL uptime: | 0 days, 01:31:32 |
6. Data rate: | 147 / 21154 |
7. Maximum data rate: | 151 / 24534 |
8. Noise margin: | 6.2 / 6.1 |
9. Line attenuation: | 31.3 / 27.9 |
10. Signal attenuation: | 10.3 / 26.4 |
11. Data sent/received: | 14.5 MB / 56.0 MB |
12. Broadband username: | |
13. 2.4 GHz Wireless network/SSID: | |
17. 5 GHz Wireless network/SSID: | |
22. MAC Address: | |
Any hope of getting the external fault looked at?
Thanks, Jayne
11-01-2019 5:29 PM
I'm dealing with this now as it happens!
I'll come back to you shortly when I've had a chat with our suppliers.
Best wishes
Dave
