Plusnet Hub One - Firewall?
- Plusnet Hub One - Firewall?
03-09-2017 11:44 AM
Had a look at the Hub One setup - I'm an old hand at such things.
Bit disappointed that I couldn't do what I thought a firewall should do - block specific domains.
I looked at your safeguard options and thought I'd give it a go - enabled it, restarted the hub and entered a domain name to block as a test.
It didn't work, then I noticed a message at the top of the Safeguard screen that said it could take 2 hours for any changes to take effect!
Can I have a PROPER hub/firewall please?
I need control of my access not corporate (slow) oversight
Re: Plusnet Hub One - Firewall?
04-09-2017 4:58 PM
You can have as good a router as you can afford but in exchange for effectively a free one (you only pay P&P), not courtesy of Plusnet. The PN router is a rebadged BT Home Hub 5A. Unfortunately if you want something better you have to put your hand in your pocket.
