Plusnet Firewall EE Wifi Calling
funkymonkeyboy
Apologies if this has already been discussed but I couldn't get Wifi Calling to work with the Plusnet Broadband firewall settings on high, but when I changed them to low and restarted my router, Wifi Calling started to work.  Is this something that Plusnet can change in their high settings to allow Wifi Calling? Or will I need to keep the firewall on low.
Thanks.
rongtw
Fixes: 12
Re: Plusnet Firewall EE Wifi Calling
If PN free firewall is giving you problems , you can always try a third party free on or even use the one Built into windows Thumbs Up  mine is set on low and i use windows firewall
https://www.techradar.com/news/the-best-free-firewall
funkymonkeyboy
I use a software firewall too on my main computers and I have one built into my ASUS router. But the one on Plus Nets side was the one giving me problems. But I’ll just leave it on low as my WiFi calling works ok now. Just glad I finally found out why it wasn’t working.
