Plusnet Fibre to Fibre Extra - No speed change after a week
Tob
I received an email on Thu, 22 Nov,2018, 01:39 (7 days ago)
to tell me that my upgrade is now compete.
I've been on the phone three times to Plusnet support once for an hour and still no change in the speed.
Has anyone got any suggestions to help me resolve this problem thank you.
13 REPLIES 13
Mustrum
Fixes: 77
Re: Plusnet Fibre to Fibre Extra - No speed change after a week
What speeds is your line capable of? Check on the DSL checker.
How are you checking your speeds?
Are you able to log into your router to check sync speeds and max attainable speeds?
Tob
Thank you for your reply I ran the speed checks as you suggested and all seems good.
So I have decided to cancel the fibre extra and returned to fibre.
I found the whole experience with plusnet unsatisfactory.
BD
Fixes: 86
Hi @Tob and welcome to the Community Forums.
Checking into your account and connection from this side I can see your estimates for the line are:
50 - 70.4Mbps download
11.6 - 17.8Mbps upload
When testing your connection however there looks to be a fault being detected which explains why you haven't seen a increase in your speed upon the upgrade to Fibre Extra as expected.
I have raised the fault to our suppliers and open a fault ticket on your account which can be seen below and we should know whether the issue will be resolved externally or if a engineer is needed to attend the property within the next 72 hours. I'd suggest if you haven't heard anything from our faults team by Monday evening to drop us a message on here and ee'll happily chase this up for you.
Fault ticket:
https://www.plus.net/wizard/?p=view_question&id=185130781
rob14
I'm in exactly the same situation as Tob. A week ago I called to upgrade from regular fibre to Fibre Extra. Got an email on Monday, telling me the switch was complete. But the speed is exactly the same as before: 50Mbps down and 9 up. The new estimated speeds are between 74 - 80 down, with a minimum guaranteed speed of 69.3. Granted, I have been using the old Openreach modem with an Asus router, so tried the Hub One, with exactly the same results. Tests have been carried out on my line, remotely, and no errors have been found. If nothing's changed by next Tuesday I'm going to have to cancel the new contract. I've been with Plusnet for years and have never had any issues before, but this is disappointing.
deank
Fixes: 14
Hi @rob14,
I've ran checks on your line for you, and a few settings appear to be incorrect on the system. I have adjusted these for you, which should take effect within 48 hours. Please let us know if you don't see an improvement by then.
rob14
Thanks for your help, Dean. Fingers crossed.
Rob
Fixes: 1,600
No problem Rob.
Let us know how your speeds look on the 04/12/2018.
rob14
Thanks for your help on this. It increased overnight. It's not quite as high as I hoped for, but it's improved.
MasterOfReality
Fixes: 57
Hi @rob14
I've just been testing your circuit to see your speeds and I can see that you are currently not in sync - your router is not syncing with the RDSLAM port. We need to check the functionality of your router before raising this to our suppliers to investigate.
Can you please confirm if your router is showing any lights which are different to normal?
Could you please also try to set your connection into the test socket and see if the service resumes - how to locate your test socket can be found here
Let us know how you get on with this and we can progress forward accordingly
Thanks,
MoR
rob14
I'd been abroad for a few days and the router had been turned off while I was away. It's now back on and the speeds are okay. Still not quite what I'd hope for, but okay.
MatthewWheeler
Fixes: 479
@rob14 Sorry to hear this,
The line is testing pretty much perfectly as shown below.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 214.9
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-55M Downstream 6dB, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-11-27T16:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 54.9 Mbps 79.9 Mbps 57.6 Mbps
Up Stream Line Rate 9.9 Mbps 20.0 Mbps 11.0 Mbps
Up Time 0.0 Sec 900.0 Sec 509.7 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-12-10T15:45:28.477+00:00 2018-12-10T16:00:28.477+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Can you advise what speeds you're currently seeing?
 Matthew Wheeler
rob14
Think Broadband's speed test has given me the following results. Am I being too greedy? I'm working directly upstairs from the router, wirelessly. It's a small, modern house.
Fixes: 1,600
The speeds you're getting are what I'd expect over a wireless connection and to be honest also over a wired connection. You'd very rarely get exactly what your router is in sync at due to the way broadband works.
Are you able to run a speed over a wired connection to compare?
