Plusnet Fibre (FTTC) and use of own router
- Plusnet Fibre (FTTC) and use of own router
26-02-2018 5:53 PM
I've been a plusnet customer ever since plusnet started. I'm considering upgrading to fibre (FTTC) and would like to do it by self install using my own Draytek 2860 router; is this a possibility?
Re: Plusnet Fibre (FTTC) and use of own router
26-02-2018 6:28 PM
Hi FTTC these days are all self installs since Openreach stopped providing their own modems and yes you can use your own modem/router I'm using a Openreach ECI modem with a Asus RT-N66U Router without issues.
Just be aware that Plusnet wont provide support for them so it maybe best to still order the Hub-one and keep it as a spare and for testing purposes should a fault develop.
26-02-2018 6:55 PM
Hi Terranova667,
Thanks for the tip re support and testing.
