Plusnet Fibre Extra Speed
goatty2
upgraded to fibre extra 12 days ago and still no change in speed,
Thank you for responding to the Ticket - 165554675,
I have tested your Broadband connection and your Router is connecting at 35.0 Mbps,
had a better speed in November so no point in using fibre extra
think I will cancel contract
have I been put on fibre extra
harrow
Re: Plusnet Fibre Extra Speed
Correct,
if PN will allow you to cancel ?
Ticked off
PN, where did it all go wrong ?
goatty2
got 2 days left to cancel
Fixes: 31
What speeds does it say you should get on the DSL Checker?
And what are the connected speed and max attainable speeds shown on the Helpdesk tab of your router - assuming its a Hib One?
goatty2
cab 29
netgear d6400 stats
Show Statistics
System Up Time 10 days 03:40:33
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN ADSL Link 13946283 15855775 0 1551 4152 9 days 08:14:01
LAN1 1000M/Full 17441165 19117579 0 167700 250729 02:23:33
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
2.4G WLAN b/g/n 145M 1453351 2587637 0 753 675 10 days 03:39:31
5G WLAN a/n/ac 1300M 6624968 3133446 0 4135 433 10 days 03:39:31
ADSL Link Downstream Upstream
Connection Speed 34998 kbps 3494 kbps
Line Attenuation D0( 18.0) D1( 47.2) D2( 72.6) dB U0( 3.1) U1( 37.9) U2( 56.7) U3(N/A) U4(N/A) dB
Noise Margin D0( 5.Cool D1( 5.Cool D2(N/A) dB U0( 6.0) U1( 6.2) U2( 0.0) U3(N/A) U4(N/A) dB
Fixes: 31
It looks like you are synching at the lower end of the impacted line and even if your line was better, there is not much point in upgrading to extra as your line is not capable of getting higher speeds.
Not sure if you can get DSL stats by telneting into your router, I have a D7000 and I can, and so ca see the max attanable speeds.
Have you tried plugging into the hidden test socket on your master socket, if you have one?
goatty2
can't remember if you can telnet my router I'll do a search
have a new master socket front after line dropped from 38 to 32
i'll try the test socket in the morn
goatty2
test socket did not work
tried to telnet router and so far can't get it to work
no change in speed tests
Fixes: 31
Something is not right if your test socket does not work.
To get into telnet, first you need to type the following:
http://192.168.0.1/setup.cgi?todo=debug
goatty2
telnet on that address asks for password then 404 not found came up
ip address is 192.168.0.1
Fixes: 31
If you have updated to the most recent firmware, it asks for the username and password, older versions don't.
But unless you have changed it, the default is:
username= admin
password= password
goatty2
it has the latest firmware and have set my own password
goatty2
managed to run via test socket and speed just the same
goatty2
canceled contract today and gone back to just unlimited fibre
hopefully this doesn't muck up my speeds
harrow
Well done, saved yourself some money.
My own fttc broadband would max at 33mb so there was no point in paying for anything faster.
Cool smiley
