Plusnet Fibre Extra Speed Is really low
FIXED- Subscribe to RSS Feed
- Re: Plusnet Fibre Extra Speed Is really low
15-11-2017 12:46 AM
I need some help as I’ve noticed really poor performance lately from my fibre extra.
Fibre extra boasts up to 76mbs download speeds however if I do a speed test (WiFi) then I only seem to be getting up to 7mbs!? I’m on an iOS device at the min so this test was through a third party site.
I’ve checked my cabling is ok and I’m going direct into a double master socket so no need for micro filter. I have a Plusnet TR3 wireless router.
Can someone help to trouble shoot this with me please?
Fixed! Go to the fix.
15-11-2017 2:54 AM
15-11-2017 7:32 AM
15-11-2017 8:22 AM
If you have a Hub One unit that plugs straight into the phone socket (ie. no Openreach box), point a web browser 192.168.1.254 and log in.
Go to Advanced Settings -> Broadband -> Connection.
It should reveal the downstream and upstream line speed.
Real internet speeds may be lower if there are other issues. eg. line fault, congestion, packet loss etc.
15-11-2017 8:33 AM
cheers Bill. I'll give it a go on my lunch time. Just to confirm, when you said 'No Openreach Box', did you mean the microfilter? I only ask as the master socket is obviously an 'Openreach Box' and I'm direct into here.
15-11-2017 11:49 AM
Sorry for not making it clear, I meant to quote no 'Openreach VDSL2 modem' (made by Huawei or ECI) which were supplied with earlier Plusnet routers more than 2 years ago, prior to the introduction of the current 'Hub One' routers (Rebadged BT Home Hub 5).
15-11-2017 5:45 PM
15-11-2017 6:09 PM - edited 15-11-2017 6:18 PM
Those look suspiciously like speeds for an up-to 17mb ADSL connection.
Log into the hub and go to the Troubleshooting -> Helpdesk.
Scroll down to the bottom of the page and until you find the line 24 called 'Modulation'.
Does it report G992.1 Annex A (ADSL) or G993.2 Annex B (VDSL fibre) ?
15-11-2017 6:39 PM
15-11-2017 6:57 PM
I think you will need to contact Plusnet. There is nothing you can do from your end.
Plusnet agents seem to be a bit thin on the ground on this forum today. May be we can get the attention of @Gandalf who did respond to another thread earlier today.
15-11-2017 7:05 PM
15-11-2017 9:30 PM
