Plusnet Fibre Broadband vs Fibre Extra
debbiejones1999
I'm looking to get a broadband connection for my holiday flat. I only need it for email, browsing the web and streaming music. It won't be for gaming or streaming movies though.
I've looked at the comparison below and see there is £3 difference between 36mb and 66mb
Plusnet broadband prices
My question is do you think 36mb is sufficient for my needs? In particular I'm concerned about streaming music. Will 36mb be ok for this?
Debbie
5 REPLIES 5
JOLO
Fixes: 77
Re: Plusnet Fibre Broadband vs Fibre Extra
@debbiejones1999,
Welcome to the forums!
36Mbps should be more than sufficient for the needs you've listed.
Fixes: 396
Hi @debbiejones1999 ,
Music streaming requires nowhere near 36Mb/sec!. It needs between 384 kbps and 2Mbs depending on the quality.
Anyway, 66Mb may not be available, depending on how far you are from the cabinet. What does the dslchecker say is the estimated speed for your line https://www.dslchecker.bt.com/
NB if you post the information from that , make sure you redact the phone number as this is a public forum
debbiejones1999
Thanks JOLO!
debbiejones1999
Ok thanks very much MisterW.
Sorry, I had no idea what music speed would require so thanks for your help.
Fixes: 49
@debbiejones1999 Remember the checker may be quoting an "up to speed"
I'm on a solid 37 download and easily stream content to my TV via Chromecast. To give you an idea I had no problems doing this when I was receiving around 6 down.
