Plusnet Fibre Broadband down since 6.30pm 29th November?
DJMC
I think the whole of Plusnet Broadband has been down since 6.30pm yesterday. I tried phoning shortly thereafter and had a recorded message tell me the queue time was an hour - always a good indicator the whole system has gone down.
Still not working today (I'm on my mobile hotspot).
One star from 1605 reviews - seems about right: https://uk.trustpilot.com/review/www.plus.net
MattyC
Champion
Fixes: 46
Re: Plusnet Fibre Broadband down since 6.30pm 29th November?
Are you ok to advise the sort of errors you're getting?
You did have a brief disconnection on the night in question, but you're back up and showing in sync.
The type of usage you're transmitting shows that it's not a stale session in this instance, which I know you contacted us last Friday to discuss.
Matty
DJMC
Back up and running now, thanks.
MattyC
Champion
Fixes: 46
Thanks for confirming that to us.
