Plusnet Fiber Extra (Please help with bad speed/reliability)
haider87
Hello there,
We used to be with Plusnet broadband with a very stable connection and have now transferred to Plusnet Fiber Extra, our estimated speed are near 80/20 but we are getting far less than that and the reliability of the connection in relation to stable speed/latency is bad. sometimes it scores in the 20Mbit, sometimes it goes up to 67Mbit and once in the speed checker it jumped to 110 Mbit at one point! The upload is near 18Mbit most of the time but has jumped to 22 once.
I have attached some stats from the Hub one, if you could kindly help. It's a new fiber cabinet with a new fiber cable and our house is in a new development so the copper cables are not old at all.
etdsaunders
Fixes: 7
Re: Plusnet Fiber Extra (Please help with bad speed/reliability)
Are you having problems over wired or wireless?
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
haider87
Over both, wired and wireless.
etdsaunders
Fixes: 7
Seems you are connected at the speed you should be. You noticing the speed issues during peak hours or all the time?
haider87
I have only had the connection for two days now.  Max I am getting over wired now is 67,  the estimate for the line was 78.
haider87
I have just checked the current line speed on the members centre and it says 77.4 :-s
haider87
Also I used to get 32 latency on copper broadband in League of Legends and now i get 42, and the setup internally hasn't changed
haider87
Hello, could someone please look into this for us. I am sat next to the router now with an AC wifi connection and getting only 30Mbits. :-(
haider87
i have restarted the router and now I am getting 68 down and 18 up over wireless.... so confusing.
etdsaunders
Fixes: 7
Sounds like a gateway issue, try not to reboot anymore or DLM will punish you. In future log in and click disconnect and then connect to gateway jump if you notice slow downs.
haider87
So what does  that mean? and is it something that could be fixed?
etdsaunders
Fixes: 7
Sometimes gateways have a little fit, cause high latency and slow speeds. You can just login to router and what they call gateway hop (Disconnect & Connect)
If it happens again, can you visit Here and let us know the gateway Cool smiley
haider87
Will do, I am currently connected to gateway pcl-ag02 and getting a good enough speed.
This is located in City Lifeline House
haider87
Hi
The speed has dropped again, now connected to gateway ptw-bng01.
This is located in Telehouse West.
haider87
disconnected and reconnected to
gateway pcl-bng03.
This is located in City Lifeline House.
Speed remains at 20-30Mbits on a 80Mbit connection.
