Plusnet Fiber Drop 38Mbps to 12mbps
FIXED- Subscribe to RSS Feed
- Plusnet Fiber Drop 38Mbps to 12mbps
Re: Plusnet Fiber Drop 38Mbps to 12mbps
24-01-2018 9:57 PM
Tried it line is busy
see what happens tomorrow bud
thanks for your concerns
Part of life living
24-01-2018 9:59 PM
It gave me the options mate
Part of life living
24-01-2018 9:59 PM
2 quiet test
24-01-2018 10:01 PM - edited 24-01-2018 10:08 PM
https://www.plus.net/my-account/tools/phone-troubleshooter/
Check my line
It'll auto log fault. if one
24-01-2018 10:06 PM
I done it it kept saying quiet time test that's it, I will see what the support suggest tomorrow bud oh by they just went off again should I be a bit sinic or is it coincidental.
Hope yours get sorted soon
Part of life living
24-01-2018 10:11 PM
Your looking out for noise/static/crackle.
Run following
24-01-2018 10:12 PM
Tried it and this happen I have attached photo
Will be speaking to someone tomorrow bud
Thanks for you help on this
Part of life living
24-01-2018 10:14 PM
no crackle
Part of life living
24-01-2018 10:14 PM
I had that in dec, turned out to be battery contact fault. gd luck tomm.
24-01-2018 10:15 PM
Thanks bud
Part of life living
25-01-2018 4:00 PM
Well looks like there is a fault an now being sent to openreach to dill with it fingers crossed it will be sorted by tomorrow.
Well I hope so. Thanks for your understanding and help you gave me.
I hope your problem will get sorted to buddy
Part of life living
27-01-2018 6:08 PM - edited 27-01-2018 6:17 PM
Not bad with dropouts today only 1 but then was told this will be fixed yesterday and now there is slow speeds
Just thought I would put this on here
Part of life living
28-01-2018 10:18 PM
I recall you had error when doing line test, and you mentioned your speaking to someone. last hurdle, keep galloping.
28-01-2018 10:23 PM
Yes mate wont be back till Tuesday so find out then,
I rather stick to one all the time so they know the history and also he did not want us to go so I though I give them a chance
Cheers mate
Part of life living
29-01-2018 9:39 AM
