Plusnet Fiber Drop 38Mbps to 12mbps
Bluejay5
Re: Plusnet Fiber Drop 38Mbps to 12mbps
Tried it line is busy
see what happens tomorrow bud
thanks for your concerns
I love hobnobs you can nibble and then take a chunk out of it
Part of life living
Bluejay5
It gave me the options mate
Part of life living
Faizan786
2 quiet test
Faizan786
https://www.plus.net/my-account/tools/phone-troubleshooter/
Check my line
It'll auto log fault. if one
Bluejay5
I done it it kept saying quiet time test that's it, I will see what the support suggest tomorrow bud oh by they just went off again should I be a bit sinic or is it coincidental.
Hope yours get sorted soon
Part of life living
Faizan786
Your looking out for noise/static/crackle.
Run following
Bluejay5
@Faizan786
Tried it and this happen I have attached photo
Will be speaking to someone tomorrow bud
Thanks for you help on this
Part of life living
Bluejay5
no crackle
Part of life living
Faizan786
I had that in dec, turned out to be battery contact fault. gd luck tomm.
Bluejay5
Thanks bud
Part of life living
Bluejay5
@Faizan786
Well looks like there is a fault an now being sent to openreach to dill with it fingers crossed it will be sorted by tomorrow.
Well I hope so. Thanks for your understanding and help you gave me.
I hope your problem will get sorted to buddy
Part of life living
Bluejay5
Not bad with dropouts today only 1 but then was told this will be fixed yesterday and now there is slow speeds
Just thought I would put this on here
Part of life living
Faizan786
I recall you had error when doing line test, and you mentioned your speaking to someone. last hurdle, keep galloping.
Bluejay5
@Faizan786
Yes mate wont be back till Tuesday so find out then,
I rather stick to one all the time so they know the history and also he did not want us to go so I though I give them a chance
Cheers mate
Part of life living
Faizan786
I also been given Tuesday as a resolution regarding all our problems, I think bt finally being pressured to pull finger out by PN.
