Plusnet Fiber Drop 38Mbps to 12mbps
FIXED- Subscribe to RSS Feed
- Re: Plusnet Fiber Drop 38Mbps to 12mbps
05-11-2017 3:02 PM
Hi there
We have had this problem for at least 6 months and now getting cross.
Our broadband keeps cutting off and speeds drop from 36mbps to 12mbps.
We had a BT Technician the third time put a brand new open reach socket in checked our area substation and all OK.
Checked all settings on Broadband refreshed the settings and reset.
Not sure what else is causing it Modem is away from electric interference.
I have attached some pictures.
Part of life living
Fixed! Go to the fix.
on 05-11-2017 3:03 PM - last edited on 05-11-2017 3:31 PM by Mav
part 2
Moderator's note by Mike (Mav): Personal information removed from attachment in a public forum.
Part of life living
05-11-2017 3:45 PM
05-11-2017 5:06 PM
I may have to see if we can terminate our contract
Part of life living
05-11-2017 6:50 PM
Have you considered going through any fault diagnosis, or reporting a fault?
Have you done a quiet line test? Dial 17070 option 2 from a corded phone.
You won't be able to terminate your contract if you have not even given them a chance to rectify a faukt.
05-11-2017 7:05 PM
Are you testing on wired or wireless connection?
What does the DSL checker say for your line.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
05-11-2017 9:24 PM - edited 05-11-2017 10:29 PM
Thanks for the link your being very useful
here is the attached photo
P.S With wired or wireless connection? it does it on both
Part of life living
05-11-2017 10:34 PM
And the answer to my questions?
You should be getting great speeds, but now and then faults can occur, water, dodgt connections, and other problems can happen, but the basic line tests can help work out what the issue is.
06-11-2017 8:56 AM - edited 06-11-2017 8:57 AM
The DSL checker results confirm the speed that PlusNet suggested you should be able to get. It is clear there is a fault somewhere if you are below this so you need to run basic checks and then raise a fault with PlusNet.
I don't have the links to hand but you need to run a "quite line" test on the phone line and then run broadband checks. These should always be done over a wired connection and make use of the test socket behind the Master socket face plate, They include running speed checks using the BT Wholesale speed test as these "log" the results on the OpenReach system.
06-11-2017 10:37 AM
Hi Brian
We done all the above and still have the problem,from six months of this, just seems to go around circles we will take it up with plusnet.
Thanks for you help
Part of life living
07-11-2017 4:54 PM
07-11-2017 11:05 PM - edited 07-11-2017 11:07 PM
Hi
Many thanks the reason we did not want to pursue this as we are on disabled money and we cant afford the £65 pounds call out fee if there was nothing wrong.
Again many thanks we will give Plusnet a call and see were we go with this
PS All those phone checks corrections have been done all ready!!!
Part of life living
11-11-2017 12:51 PM
Just thought that this may be an interest to you
Part of life living
12-11-2017 9:46 AM
Well I have a feeling that Watchdog going to be busy soon
Part of life living
14-11-2017 9:46 AM
Getting worse complaint as been issued
Part of life living
