Plusnet FTTC -> TD-W9970 -> UDM
FIXED- Subscribe to RSS Feed
- Plusnet FTTC -> TD-W9970 -> UDM
16-04-2021 7:49 AM
I am having issues trying to get this working. And there are some things I am clueless about, so hoping someone can point me in the right direction.
Existing network: Plusnet hub one router - DHCP disabled, wifi disabled. ip address is 192.168.1.254 plugs into a switch which has a UDM hanging off it it using LAN ports (not using WAN port) - entire network on 192.168.1.0/24
So I have a TPlink TD-W9970 which I have tested as a like for like plusnet one router replacement and it works fine.
What I want to do next is put the TD-W9970 into bridged mode and plug the WAN port into the UDM WAN port.
TD-W9970: Disabled DHCP, wifi disabled, configured in bridge mode, do I need VLAN 101 or just straight through ? IP address is 192.168.1.254.... this is the same address as my PlusNet router - should I change this to 192.168.0.254 and keep it on a separate network as 192.168.1.0/24 is my main internal network....
Connect WAN port on the TD-W9970 to the UDM WAN port.
configure the UDM WAN as PPOE with my plusnet account and password ... anything else here ?
For my internal DHCP network, do I then need to change the gateway address to the UDM ?
Any thoughts or suggestions would be most welcome....
Thanks in advance
Darren
Fixed! Go to the fix.
16-04-2021 10:19 AM
do I need VLAN 101
Yes
Shouldn't matter if its in bridge mode as you cant get to it from your network. You would need to connect directly to one of its LAN ports to access it.
Close, but no cigar! . You need to connect a LAN port on the 9970 to the UDM WAN port.
If the UDM is not the DHCP server, then yes
Advanced setup
If the UDM can support a WAN alias IP and static routes, then change the 9970 to 192.168.0.x and give the UDM a WAN alias in the same subnet, then you MIGHT be able access the 9970 via the internal network
Re: Plusnet FTTC -> TD-W9970 -> UDM
16-04-2021 11:35 AM
Thank you MisterW
As soon as I can get down time from the wife and kids I'll give this a try.
16-04-2021 11:58 AM
