Plusnet Changing my Static IP on Fibre
- Re: Plusnet Changing my Static IP on Fibre
22-01-2015 11:27 AM
22-01-2015 11:42 AM
Quote from: Matthew Most customers that are affected have been e-mailed already.
The only range left are 212.159.17 and 212.159.48
Thanks for that Matthew.
I've not received the email and my IP address is in the range 212.159.109.xxx so I don't expect it to change then!
22-01-2015 11:44 AM
22-01-2015 11:52 AM
also assume not affected?
22-01-2015 11:55 AM
Anyone affected will have either received an email about this already, or be receiving one in the coming days.
22-01-2015 12:39 PM
22-01-2015 12:40 PM
22-01-2015 12:45 PM
probably would have been a good idea to post a notification about this on here as well and on support pages.
22-01-2015 1:20 PM
Quote from: Matthew I can change it for you now if you'd like?
Yes please bring forward if possible.
22-01-2015 1:38 PM
81.174.151.x range?
Cheers
22-01-2015 1:42 PM
The only ranges left to email are 84.92.128.0 to 84.92.191.255
22-01-2015 1:42 PM
Quote from: Halfchan
I'll reply to your ticket with the new IP you'll get from the next time you disconnect/reconnect.
22-01-2015 1:45 PM
22-01-2015 2:06 PM
Quote from: Chris If you've received an email, yes. If not and your IP isn't in the ranges below, no.
The only ranges left to email are 212.159.17 and 212.159.48
You have no way of knowing if people have successfully received their emails so I'd suggest posting a full list of the IP ranges affected would be a smart move.
22-01-2015 2:09 PM
