PlusOne router and Macbook
- Re: PlusOne router and Macbook
05-02-2016 12:57 PM
Just the other day my macbook refuses to connect with our PlusOne via wifi, it is saying invalid password.
All other macs, phones, tablets work fine. Any thoughts?
I've tried a restart of macbook.
Message 1 of 6
(1,458 Views)
5 REPLIES 5
05-02-2016 1:03 PM
try splitting the 2.4 and 5GHz networks, that helped with our MBP that sorted our issue out.
Message 2 of 6
(690 Views)
05-02-2016 11:37 PM
Not sure what you mean....do you mean disable one of them? I am certain the MB is old and its 2.4.
Message 3 of 6
(690 Views)
06-02-2016 8:51 AM
In advance wireless settings change the ssid of one of them. I just added a 5 on to the end of the 5ghz one.
We had issues with a 2009 MBP, which is quite old.
Message 4 of 6
(690 Views)
06-02-2016 12:45 PM
@dvorak is your ipv6 fix relevant here?
Message 5 of 6
(690 Views)
06-02-2016 9:06 PM
shouldn't be - that's more to do with the hub zero and it crashing the MBP.
though I haven't tried switching IPv6 on again.
Message 6 of 6
(690 Views)
