PlusNet cheating Speedtests?
- PlusNet cheating Speedtests?
01-05-2020 3:37 PM
I've noticed that when I'm having poor internet performance I'll got to Ookla and speediest the connection. It will pull a number like 5-7mbps only to then magically pick up and deliver precisely the minimum guaranteed speed from Plusnet.
Not only this but then subsequent tests despite often being to a different target will also suddenly be better.
Could Plusnet be manipulating this? I'm sensing a note to Ofcom as I've had connection problems with these guys for some time and whilst they can't help Openreach's incompetence this behaviour points directly to Plusnet.
Has anyone else experienced similar or can anyone shed any light on this please?
Re: PlusNet cheating Speedtests?
01-05-2020 5:24 PM
Hello there @Dubbs,
I'm sorry you've had some trouble with the speed of your service, I can assure you that we do not manipulate your speeds as soon as you do a speed test to bring it in line with your minimum guaranteed speed - we don't proactively monitor your line either.
Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
Thanks.
01-05-2020 5:28 PM
A lot of speedtesters use multithread to gauge the speeds. Try the Thinkbroadband one (https://www.thinkbroadband.com/speedtest) which also measures single thread speed. The two lines should be as close together as possible. If a big gap, it could show capacity issues or wireless problems. Always check with a wired connection for the most accurate results.
01-05-2020 7:13 PM - edited 01-05-2020 7:24 PM
Thanks Marksfish for that link
Very interesting just did tests on EE standard U/G and PlusNet 4G mobile broadband tethering via phone
EE standard U/G Download 13.0 Mbps Upload 0.7 Mbps
PlusNet Mobile Tethering Download 44.7 Mbps Upload 10.9 Mbps
I thought the mobile tethering was good when I used it at the caravan but not that good
Will wait for Three 5G U/L mobile broadband to come to my area and see what that's like
