PlusNet Hub One, static IP bridge mode
vettrainos
I have recently placed my order with PlusNet for Unlimited Fibre to replace my existing ADSL service. In order to work from home I need to utilise a service that provides static IP which PlusNet does. However, I have been unable to ascertain if the PlusNet Hub One will operate in Bridge Mode to permit my connected client device to be assigned the static IP (as I require). Does the PlusNet Hub One provide Bridge Mode operation or will I need to purchase an alternative VDSL modem such as a DrayTek Vigor 130?
40 REPLIES 40
w23
Fixes: 4
Re: PlusNet Hub One, static IP bridge mode
The Hub One is pretty much the same beast as BT HomeHub 5A, I don't think it can be configured as a bridge but this may be a suitable work-around: https://community.bt.com/t5/Connected-Devices-Other/Configure-Home-Hub-5-as-modem-only/m-p/1438417#M...
Call me 'w23'
vettrainos
Thanks for identifying the possible workaround, but... unfortunately that doesn't help. I need my client machine to be assigned the static IP assigned to my PlusNet account as a result of the security constraints that need to be applied by my workplace.
w23
Fixes: 4
It might be worth asking Plusnet if they could supply you with a BT OR modem (if they have any left), that should be pre-configured as a simple bridge.
Call me 'w23'
vettrainos
Thanks for the suggestion "w23", I'll have a look at progressing that route 🙂
vettrainos
PlusNet have identified that the Hub One is the only device they provide to connect Fibre customers to their service. As a result, any further direction on a best solution is welcomed.
Darkfire
Fixes: 30
As far as I am aware we are now out of stock of the Openreach modem's which is most likely why one couldn't be sent to you, however these can be picked up fairly cheap online, otherwise any VDSL compatible modem/router that has the ability to assign the external IP to a device will work fine
TheSanctuary
Has anyone found a way of setting a Hub One to Bridge Mode?
Or do I have to get a better vdsl router/modem?
Edit: is it too late for me to cancel the Hub One as part of my order?
Fixes: 385
Just for info, we're using a TG589n in bridge mode in the office on a ZEN FTTC connection. It's linked to a Firewall box which does the PPPoE, and works fine.
TheSanctuary
Err, is a TG589n the same as a Hub One?
Strat
Fixes: 565
No, the Hub One is a re-badged Home Hub 4.
Mustrum
Fixes: 76
Sorry to break forum rules, spesh on a mods quote, but the Hub One is a re-badged Home Hub 5. - I am sure it was a typo  Wink
dick:quote
Typo duly noted....it's a 5A.
TheSanctuary
Fair enough, so my question remains:
Darkfire
Fixes: 30
Unfortunately  this  cannot be done with the Hub One,  personally I use an Openreach(Huawei) Modem which allows my PfSense box to connect via PPPoE
I'd suggest getting a VDSL combined modem/router though as it'll mostly be plug and play with simple options for bridging the connection  Smiley
TheSanctuary
@Darkfire,
Thanks, that's fair enough, just wanted to know.
Is it too late for me to cancel that Hub One part of my order?
