PlusNet Hub One Alternative
zelnaga
Hi All,
I recently upgraded and got the new HUB one router which seems too weak as it can't reach the other side of the house (the older plus net router did without any issues).
I was wondering whats the best replacement router we can use to replace the HUB one?
2 REPLIES 2
Manny7860
Re: PlusNet Hub One Alternative
Bt smart hub 6
Suppose to have the best Wi-Fi range
Excellent!
jaread83
Fixes: 81
If its a Fibre router you're after, Kitz forum has a good thread about alternative routers:
http://forum.kitz.co.uk/index.php/topic,14436.0.html
