PlusNet, Have I got G.INP enabled on my Cabinet?
danludlow
My recent speed boost has remained unchnaged, thankfully. My port was changed by OR engineer about 3 months ago, I was on card one with G.INP enabled, and was moved to card two which I don't think had it. Engineer didn't know. Recent speed increase and halving of latency suggests a change has taken place.
Can PlusNet find out if I have G.INP enabled please, and whether this happend in the last fortnight.
Fixes: 236
Re: PlusNet, Have I got G.INP enabled on my Cabinet?
I'm just having a look now.
[edit]
Your profile is "0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off" so you don't have G.INP on at the moment.
 Matthew Wheeler
danludlow
Thanks for looking Matthew, I'm sure that I did on card one, and thought I hadn't on Card two (my new home in the street cabinet). I'm getting great speeds just now and not seemingly thanks to G.INP. Can or will G.INP be enabled at some stage, and what advantages, if any, would it bring? Considering my high current speeds (above theoretical for distance from cabinet), i can't see any benefit. Best left alone, I suspect, but definately improved my connection Once upon a time.
Fixes: 236
Potentially it could depending on wherever DLM think it's best for your line.
Unfortunately we can't set it manually.
 Matthew Wheeler
