Plus net virtually unusable
Portperran
We have had fibre broadband vis Plusnet for about two years with no problems until about 2 weeks ago.
Now....virtually unusable.
Have contacted support who suggested changing channels. I've tried them all with no improvement.
Raised another fault via internet on Monday but no reply.
Any ideas?
Fixes: 167
Re: Plus net virtually unusable
That sounds like you've been through the wireless troubleshooting. Do you have any problems if you use an ethernet cable rather than a wireless connection?
 Chris Parr
 Plusnet Staff
runhare
Hi Portperran,
What is your set up? which model of router are you using? What kind of computers or devices are connected? What are the operating systems in use ?
When you say the internet is unusable, can you describe in a bit more detail the symptoms?
All the above is useful info before forum members can start to suggest ways to assist you.
