Please confirm my speed test results
FIXED- Subscribe to RSS Feed
- Please confirm my speed test results
18-01-2020 10:12 AM
Can someone please tell me if I am getting the right speed? I've attached a screeshot of the DSLchecker but when I do a speedtest it only gives me 59 up and 18 down. I'm happy with the up but could I get more on the download side?
Thanks for any advice.
Fixed! Go to the fix.
Re: Please confirm my speed test results
18-01-2020 11:24 AM
59 fits pretty well between 49.2 and 71.5 so what's the beef?
18-01-2020 11:31 AM
Nothing's wrong. Just gready 😁 I've noticed that my router re-boots every couple of days and wondered if that was why I wasn't getting 70 up like the checker says.
Is that normal for the router to go down by itself? There hasn't been any new firmware updates recently. That usually entails a restart but the last one I have is March 2019.
18-01-2020 8:36 PM
Your DSL Check shows you are synching 73.75/19.53 which is abve the estimates.
You will never get those speeds on a speedtest as there so many other factors to consider, not least anything else using your router or testing device.
Looks OK to me.
