Please Help! Slow Broadband in the evenings for a month now.
Bluejay5
Re: Please Help! Slow Broadband in the evenings for a month now.
@Faizan786
How is your speeds doing mine is up and down and had one dropout
Cheers mate
I love hobnobs you can nibble and then take a chunk out of it
Part of life living
Faizan786
Waiting on QA BT to let @Gandalf  know.
Fixes: 1,600
Our suppliers have completed the move to a different VLAN.
Can you confirm that your speeds are now back to normal (Might have to wait until tonight...)? -Anoush
Faizan786
I'll post random speed tests in evenings in coming days.
I noticed internet turn off at 1am today for about 2 minutes, maybe  that was the vlan change?
My Broadband Speed Test
Fixes: 1,600
It’s possible.
Looking good at the moment. Thumbs_Up Keep us posted over tonight if you can, and I’ll let QA know it’s worked so they can add this as an example to their further investigations.
Faizan786
how often would you like results, im off work and willing to help so it benefits others.
Fixes: 1,600
Cheers for your help, though I think a yea or nay might just be needed.
Our suppliers should then be able to analyse it their side, check what they’ve done to resolve the problem (I believe a VLAN change isn’t as straightforward as you and I might think as there’s a lot of variables and moving parts) and then figure out any common themes with other circuits in a similar situation.
Faizan786
