Please Help! Slow Broadband in the evenings for a month now.
- Re: Please Help! Slow Broadband in the evenings fo...
- « Previous
- Next »
Re: Please Help! Slow Broadband in the evenings for a month now.
28-01-2018 1:38 PM
How is your speeds doing mine is up and down and had one dropout
Cheers mate
Part of life living
28-01-2018 10:08 PM
Waiting on QA BT to let @Gandalf know.
30-01-2018 10:31 AM
30-01-2018 7:37 PM
30-01-2018 7:39 PM
Looking good at the moment. Keep us posted over tonight if you can, and I’ll let QA know it’s worked so they can add this as an example to their further investigations.
30-01-2018 7:41 PM
how often would you like results, im off work and willing to help so it benefits others.
30-01-2018 8:16 PM
Our suppliers should then be able to analyse it their side, check what they’ve done to resolve the problem (I believe a VLAN change isn’t as straightforward as you and I might think as there’s a lot of variables and moving parts) and then figure out any common themes with other circuits in a similar situation.
31-01-2018 6:34 PM
- « Previous
- Next »
