Ping spikes
Saboo2035
Ping spikes
Hi
I seem to be getting a lot of ping spikes. Im a gamer and as you can imagine its not very good when your pings jumping from 16ms to 140ms and everything in between. I was wondering could someone take a look at this please. Im on a wired connection and nothing has changed on my setup from this started happening....
Saboo2035
Re: Ping spikes
Is there anybody out there......Smiley
rongtw
Fixes: 12
Re: Ping spikes
Its weekend CS staff are sparse Sad
Are testing wired or WIFI ? what is your current speed , and are you using the PN supplied router
Saboo2035
Re: Ping spikes
hi
I didnt think there would be too many about at the weekend.....Grin
Im using a wired connection for testing.
My speed is fine its just the ping jumping   Cry
And im using my own router..
Saboo2035
Re: Ping spikes
http://www.speedtest.net/result/5738145495.png
Nothing wrong with the speed......Smiley
rongtw
Fixes: 12
Re: Ping spikes
It would help if you have a TBB graph http://www.thinkbroadband.com/ping
Create a new one by adding your IP Wink
Fixes: 167
Re: Ping spikes
How long do the jumps in ping last? Is it to any game in particular or do you notice this outside of games too?
 Chris Parr
 Plusnet Staff
